texasturbo
1982 Buick Grand National. First year Grand National. One of only 215 made. I have done a lot to this car so here goes. Fully powder coated frame. All control arms rebuilt front and rear, also blasted and painted. KYB shocks front, Gabriel HD shocks rear. Complete suspension rebuild, sway bars front (big) and rear (std). All new brake and fuel lines/hoses. Master cylinder, proportioning valve, calipers, rear brake hardware, wheel cylinders. New rotors/pads w/ bearings and seals. Replaced rear axle seals. 3.23 rear axle ratio. New fuel tank and sender, New poly body mounts. New radiator (aluminum HD K162, form tank ends). 2 speed electric cooling fan from 86 Grand National. Motor is completely rebuilt. New .030 over speed pro pistons and rings, Comp Cams 252 H10 camshaft. Block was decked. Heads completely rebuilt (springs, keepers, guides, etc. etc.). New water pump. New fuel pump. HD timing chain and roller cam button. HD oil pump, modified timing cover and oil pump passages with extended gears and 60 lb relief spring. Edelbrock intake. Edelbrock carburetor #1406 w/ elec. choke. Re-jetted with Innovative O2 scan tool. Carburetor works really well. Rebuilt 2004r over drive transmission out of 85 Monte SS. Good firm shifts. All new exhaust/muffler. Reworked HVAC air box with seals, New A/C compressor, hoses and condenser (aluminum). New ACC carpet. All gauges work. Steering wheel is in great shape for its age (original). Dash pad is in great shape for its age (original). The rest of the interior was already removed when I got the car so what is in the car is from an 85 Buick T Type that only had 68,000 miles on the odometer. Really nice for its age as well. At some point the car had a fender put on before I got it. Rest of the car has the original paint. New windshield. T tops are in good shape and come with the car. Radio works. All new speakers (Swiss Audio). New tires with the correct aluminum wheels. Mechanically and electrically the car is 100%. I never started any body work. There are still little things that need attention as you can see in the pics, so feel free to ask questions. My email is lenny.lopez@verizon.com. Text to 214-837-5750. I am sure I missed something.
I do not need help selling the car or anything like that so do not bother asking. Cash only and in my hand for a test drive, keys and a clean Texas title.
Thanks.
Thanks.
