I have a 1984 Buick Grand National that I have replaced and done quiet a bit to since I got it under the hood. Recently did injectors, chip, spark plugs (again), valve cover gaskets, and intake gasket. As well as new fuel filter and sending unit. Put all back together and got the car to start and run. So I thought win. Well it will start run, but when put into gear and try and give it throttle it stumbles over itself and pukes out. Put it back into park and it will idle just fine.
Next thing I thought I should do to help the start as its never like to start great was replace the Engine coil module, I got the conversion kit to go to the 86/87 Coil, as well as updated the crank sensor followed directions on how to do all of that. Now cant get car to start at all. Had to cut a wire when did the conversion kit and believe its getting the power electrically that it needs. But wondering if anyone can tell me how and what I can check to make sure I am getting power to everything I need. As I have had that car back fire twice on me I assume after I flooded it, sounds like a gun shot went off in my garage.
I appreciate any help! I am to the point of my mechanical abilities and going to start looking for a mechanic that could take it on just to get it running like its suppose to.
Located in North Dakota.
