1984 buick with 87 emc not primeing
neres818
car starts when i spray starter fluid but when the car is cold i need to spray starter fluid pls help
Do you mean it starts and stays on or only runs when your spray into the TB?
is your check engine light on when key turn to on? Do you hear the fuel pump prime at all? your pump might be crapped out or maybe even a fuse maybe, it's a 10 i believe.
it works fine after i spray starter fluid... it runs fine i drive around but when it gets cold i have to spray
