1985 Mustang LX V8 5 spd
LC2BUICK
LINK TO PICS: 26 PHOTOS
Garages > LC2's 1985 Ford Mustang - FQuick.com
1985 Mustang LX Hatch California factory V8 5spd
Blue/Blue
Miles over 100K
OPTIONS
V8
Rear wing delete
A/C
Manual locks
Manual windows
Rear defrost
Tilt
Cruise
New heater core
DESCRIPTION
Car came out of San Diego California. Rust free, collision free, extra clean body. Paint is faded from sun. No dings or dents in metal, although there is a tear in the left rear corner of the bumper cover. Interior is clean for age and has usual heat cracks on dash pad. Has some classic 80s stereo and EQ. Engine and Trans are stock with some minor alterations to make the serp belt work after power steering was removed. Car runs, drives, shifts as it should. One of the cleanest underside cars I have ever worked on. Car will make great street car, all suspension and chassis is done. Ready for your engine and trans. The following is a list of upgrades I have done to the car.
SUSPENSION FRONT
QA-1 tubular k-member
Moroso trick springs
UPR caster/camber plates
Strange adjustable struts
TCI line lock
Flaming River steering shaft
Flaming River manual rack
Energy Suspension rack bushings
Energy Suspension spring isolators
88 V8 spindles
New ball joints
New calipers
New caliper hoses
New brake pads
New bearings
New seals
New SVO 5 lug rotors
New tie rods
SUSPENSION REAR
8.8 Read end
FMS 4:10 gear
Welded axle tubes
T/A diff cover
UPR anti-roll bar single
Moser 5 lug axles
Moser 3 inch long screw studs
Rear air bags both sides
Granatelli double adjustable UCA
UMI solid poly bushing LCA
Eibach rear drag springs
Strange adjustable shocks
Rebuilt posi unit
New backing plates
New bearings
New seals
New brake hardware
New brake shoes
New brake hose
New 5 lug drums
New wheel cylinders
CHASSIS
UPR sub frame connectors
UMI upper torque box plates
UMI lower torque box plates
Wolferacecraft lower torque box plates
WHEELS
Weld Pro Stars
Front 3.5
New 165 tires
New closed end lug nuts & washers
Rear 15X8
Tires need to be replaced
New open end lug nuts & washers
Car in Chicago Metro Area
Bobby 630-541-7271
