1986 Buick Grand National
Status
Not open for further replies.
Randy Hagins
Up For Sale is a 1986 Buick Grand National... Super Clean, showroom condition from the ground up!!!
SUSPENSION:
1. PST poly graphite front and rear control arm bushings
2. PST poly graphite body bushings
3. Lakewood 70/30 front shocks
4. Lakewood 50/50 rear shocks
5. Air lift air bags, driver and passenger side
6. HR parts and stuff laser cut plates for rear control arms
7. New front and rear springs
8. PST tie rod ends, idler arms and drag link
9. Pinion snubber
Fuel System:
1. 42# injectors
2. XP fuel pump
3. Quad air hot wire kit
4. ATR adjustable fuel regulator
Computer Chip:
1. Red Armstrong 93 street chip
2. Red Armstrong 108 race chip
Engine:
1. Motor was rebuilt by Mike Laciura @ Wildcat Performance in March 06
2. .030 0ver Speed Pro pistons
3. Double roller timing chain
4. 206/206 Comp cam
5. High volume/High pressure oil pump-timing cover
6. Billet Aluminum center caps
7. Adjustable push rods
8. Champion ported intake manifold, EGR block off plate
9. Cosmetic head gaskets
10. 92# Comp Cams valve springs
11. Heads cleaned up with Dremel tool (Intake and Exhaust ports)
12. New water pump
13. Radiator re cored
14. All new hoses and sensors
15. High torque mini starter
16. New air conditioner compressor, accumulator and hoses
17. New heater core
18. New alternator
19. ATR cross flow exhaust
20. ATR test pipe
21. ATR 2.5” down pipe
22. Stock headers/cross over pipe coated with high temp coating
23. TE 44 Precision turbo with .63 compressor housing installed 5-09
24. Adjustable waste gate
25. Stock intercooler
26. Quad Air spark plug wires
27. Casper heated O2 sensor
28. K&N 9” air filter
29. Quad Air volt booster
Body:
1. Car was stripped down to bare metal. Doors, hood and trunk removed
New door hinges added. April – May 2005
2. Car was painted in June of 2005 with ICI paint and clear coat by
Osteen’s paint and body, Jacksonville Florida
3. New head light bezels
4. New turn signal markers
5. New parking markers
6. New front and rear bumper impact strips
7. New Soff Seal weather strip
8. New fiberglass bumper fillers
9. New emblems
10. New hood insulator
11. Rear seat brace kit
Brakes:
1. Front cross drilled rotors
2. Braided brake hose (front and rear)
3. Hurst line lock
Interior:
1. New carpet
2. Auto meter sport comp boost, oil pressure and water temp gauges
3. New headliner
4. Power “6” floor mats
5. New Pioneer and Kenwood speakers
6. New turn signal and cruise control stalk
Transmission:
1. ATR transmission cooler
2. U joints replaced on drive shaft
3. ATR drive shaft loop
4. TCS 911 lock up converter
5. Transmission rebuilt by Watson transmission, Adel Ga. Dec. 2007
Miscellaneous:
1. Various parts on the car have been powder coated
2. New center caps (4)
3. Car is garaged and covered when not in use. Avoid driving in rain
4. Estimated total cost for engine work: $2500.00
5. Cost for body and paint work: $5200.00
The car was appraised by the GSCA for 18000.00 - will take reasonable offer.
You have an AWESOME ride there, please post an asking price ok, so the guys know where to start.
Best of luck with the sale.
Did I read that right? Billet aluminum center main caps.
How much?
Some people have cars that are worth a fortune, but only get half that because they are desperate to sell. What is your asking price?
looked like $18,000. or best offer to me ???
last sentence in his ad?
"The car was appraised by the GSCA for 18000.00 - will take reasonable offer"
I apologize in advance to Randy if that is what he means, but I read it as that is what the GSCA appraised it at and he is just looking for Best offers.
Again, If I am wrong I apologize, I just read it different I guess.
I realize times are tough but lets be realistic. Do you know what all I have had done to this car? I am not in that bad of finacial need to unload this.
You're just working too hard ;)
SUSPENSION:
9. Pinion snubber
Fuel System:
1. 42# injectors
2. XP fuel pump
Computer Chip:
Engine:
4. 206/206 Comp cam
12. New water pump
17. New heater core
18. New alternator
20. ATR test pipe
Body:
9. New emblems
Brakes:
3. Hurst line lock
Interior:
1. New carpet
3. New headliner
Transmission:
Miscellaneous:
The car was appraised by the GSCA for $18,000. Asking $17,000 or best reasonable offer. Thank-you.
If it has cosmetic head gaskets, does that mean they're pretty? LOL! Good luck with the sale. You put alot of time and money in it. I hope you get what you want for it.
Randy-
The guys wanna know the miles, please post.
Thanks in advance!
Ty
Why waste peoples time not answering questions?
Status
