1980 Buick
- Aug 17, 2009
While "nosing around" my engine (and theirs NO Problem with it) ... I decided to pull the timing cover and low and behold the timing chains very "sloppy" and the cam buttons gone (or "worn") into the front cover.
*I noticed while is was up on the rack, and that I could hear / or "feel" slop in the chain ...
ALSO: *can one JB weld the "sink hole" that the plastic cam button made ? (then install the revised "Bering" on the cam end) ? on the timing cover ? < or must cover be replaced >
The oil pump looks fine ... BUT: would you recommend an upgrade ? (ie millings with "high output" pump) or just replace the gears with stock /& leave it alone. *again, no problems.
Also: can someone recommend what parts to use 4 parts? (OEM, Perf. etc ...) *The cars 100% stock.
Thanks so much in advance and you help is appr.
