1987 Buick Grand National Hardtop / Houston
sumnerw
94k miles; clean title
Centerline Telstar wheels (15”x8”) with BFG Radial TA tires (new @ 84k miles)
P215/65R-15 front and P275/60R-15 rear.
Suspension (front suspension completely rebuilt at 88k):
Global West ‘Delalum’ bushings in upper and lower front control arms;
Heat shields on D/S and P/S front upper rear bushings;
Moog front springs, tie rod ends and ball joints;
Polyurethane front swaybar bushings and end links;
Polyurethane bump stops;
Southside Machine rear traction bars;
KYB Gas-A-Adjust Shocks;
Dual rear air bags;
Lower body mount bushings added to positions 3, 4 and 5.
Engine (rebuilt at about 70k):
GN1 aluminum heads w/ ported intakes;
Billet main caps - #2 and #3;
Double roller timing chain;
TRW forged pistons;
ARP main studs and head studs;
Polyurethane D/S and P/S engine mounts.
Engine upgraded at 88k:
Comp Cams hydraulic roller camshaft;
Comp Cams hydraulic rollers;
Crane Cams pushrods;
K-Motion valve springs;
Federal Mogul main bearings;
Sealed Power rod bearings;
TA Performance hardened #1 cam bearing.
Rest of drivetrain:
3000 rpm stall, lock up converter;
ATR aluminum driveshaft;
Driveshaft safety loop;
Stock, posi 3.42 rear end (GU6; G80; G87).
Fuel system:
Walbro GSS340 fuel pump;
Hot wire for fuel pump;
MSD 50 pph injectors;
Kenne-Bell adjustable fuel pressure regulator.
Air intake and delivery system:
Ported lower intake w/ EGR tower removed;
RJC air distribution plate;
Accufab upper plenum and 70 mm throttle body
PTE54 turbocharger;
CAS front mount intercooler;
Carroll Supercharging alcohol/water injection system.
Exhaust system:
ATR stainless 3” downpipe and 2½” dual exhaust;
ATR wastegate valve on exhaust crossover;
Walker stainless steel Dynomax Ultraflow mufflers;
ATR 3” high performance catalytic converter (to pass emissions test);
ATR 3” test pipe
Cooling system:
ATR aluminum radiator;
Ramchargers dual fan sealed to radiator with trunk gasket;
160º thermostat drilled with two bypass holes;
Billet thermostat housing;
Dequick high volume water pump;
Evans overdrive water pump pulley;
Blocked water pump bypass;
Evans NPG+ coolant.
Oiling system:
Ported timing cover;
Melling high volume oil pump;
Oil filter bypass valve blocked;
PT&E “turbo saver” remote oil filter system.
Braking system:
Aluminum rear brake drums;
Line lock;
Russell speed bleeders.
Electronics:
Stock ECM with Joe Lubrant chip;
Jensen radio w/ CD player.
Electrical system:
Lightweight AC-Delco starter;
Red Armstrong volt booster.
Gauges:
Hood-mounted Autometer liquid-filled, mechanical fuel pressure;
Westach EGT and VDO 0-30 psi mechanical boost on a-pillar;
VDO oil pressure and water temperature in console mount.
Power windows and locks
Power driver seat
Dual remote outside mirrors
Interior in good condition. No tears in seats.
Ran 11.1 @ 125 mph (550 hp) before cam change. Haven’t had a chance to dial new cam in.
Buyer responsible for arranging pickup or shipping.
Asking $13,000. One week here, then it goes to eBay.
Buzz White in Houston, TX
email for pics
YES HELLO CAN YOU EMAIL ME PIC'S OF THE CAR IN AND OUT THANKS AGAIN
