1987 gn t-top car
WINDMILL
1987 grand national
109 block 30 over motor,has arp head studs, crank 10-10,204-124 cam,gn1's aluminum heads, 72inj and 68-h turbo
champion 1200 intake,precision hat with powerplate, 70 mm t/body
aluminum pullys rjc's
ATR front mount
3-1/2 thdp with atr 3 inch single exhaust
moser 9 inch rear end 33 spline with aluminum center section, 350 gears spool
Metco uppers d/adj bars,,, and metco non lowewr bars,,,ATR big swaybar,air bags
6 point chrome moly cage bolt in and removeable side bars.
notch frame for bigger tire( 325x50x15)
torque-thrust wheels front 15x4 rear 15x8 with 4-1/2 b/space
turbo 350 trans with lots of hard parts in it fron ck perf. deep pan
nitrous driveshaft
rear disc brakes
hydroboost brakes
aluminum bumper struts, no beams inside bumpers too(still have old stuff tho... exports up front.
with this motor and champion iron heads ran 6.7's at 1.45 60fts on 275x60 drag radials leaving at 5 to 6# and 21# out the back door with the 200r4,, now has 350 trans manual v/b and have the hydro boost so now i'm going to try and leave at 10# and i think it will run close to 6.5's at the same boost
also car has been before 7.0's on 255x60 grand am reg radial with a 1.62 60fts....
i'm putting motor back in this weekend so it will be running next weekend to try out for et's i hope.....
price 9,000.00 firm for car only no extra parts but will sell all other parts if someone is interested...... 256-601-6604 turbomonk@hotmail.com
pic
where all the tirekickers,, i need it to the top,,,,,,,,,,hahahahaha............. anyways i have lots of parts for sale too..... e-mail with needs.... thanks...
they are an ad where i had it for sale before i would post them but my photobuck wont work on my laptop for some reason,,,, the 350 trans was what i wanted in the car... i'm hoping to get the motor back in about next weekend, i had back surgery little over 2 months ago, so i'm going to be slow......any info you need call me 256-601-6604.....
No rush, just whenever you are able to get photobucket working I would really like to take a look at the other pics.
Can you give some more general info on the car? --> A/C work? How many miles are on it? How many miles on the motor? Shift firm and as it should? How many lbs of boost you running? Etc... Any and all info is appreciated. Thanks in advance!
http://www.turbobuick.com/forums/cars-sale/319645-1987-gn-t-top-car.html
i have a new air line to go on for the air, the sensor broke off on the driver side, but will work,, has around less 90000 on the car,,,the motor has alot of passes not alot of miles, i live like 10 min to the dragstrip,,,,, tans is new only prob 100 miles or so,,,i run around 21# with iron heads on same motor ran 6.7's with the 200r4 trans when the trans was slipping thats why i went to the 350...
well got the ole gn running couple weeks ago went thur night to test and tune,, it ran 1.75 60 ft at 7.53 at 94 mph this is on pump gas at 18# NO ALKY with reg ole radials tires NOT DRAG RADIALS,,, and still never got to leave where i wanted too,,,
