SignUp Now!hello; I saw the words bigger breaks and I thought about the PowerMaster. Did you say what brake setup your going with?
IBBY
hello; I don't think it's bashing if anyone tells there pros and cons about a product. How is a vendor going to improve. Of course there are bad days but it's a good thing to give opinions about aftermarket products good and bad.I posted early on in the thread if someone were to care enough. I don't really feel like bashing a vendor, everyone has bad days I guess /shrug
My hosting on uploadit.org is down, someone hacked their site and its been down ever since. I gave the owner of the forum my new hosting information and he said he would switch it all, so far though.......
Anyways the down pipes first issue was that the sleeve holding the bearing for the puck wasn't welded in and shifted during shipping. Took quite awhile to figure this out with phone calls back and forth between the turbo manufacturer and the down pipe maker both saying it couldn't be their part. Either way we figured it out and got the puck centered and the sleeve tack welded in. Honestly it was an easy fix but it was an hour to figure it out. And if it wouldn't have been at a shop with a welder it would have been a bigger issue.
Now that it is installed on the turbo the down pipe doesn't line up with the rest of the exhaust. With the test pipe on there is a 5-6" gap between where the exhaust ends and the downpipe ends. I know its the downpipe again because the crossmember has a notch for the exhaust to fit under and the cat back rests there with room on both sides while the downpipe is nowhere near it. 20 degrees more bend when they made it and it would have lined up fine. We also took the old down pipe and elbow just to see and it lines up perfectly. We are fixing it now but still another couple hours worth of work and a wasted exhaust coating down the drain.....
Also there was quite a bit of welding mess on the inside of the downpipe and some overlap on the flange and the tube. Enough to where we all thought it needed to be ground down to make it smooth again. Not a huge issue but it was easy to get to and a large enough restriction to where I wanted it gone and sloppy enough to be dissapointed with fit and finish after paying what I paid.
Like I said I've heard enough good things on this forum about the part that I bought it. Unless you've heard multiple accounts I would let it slide knowing everyone has a bad day now and again. On the positive side the tech support was great and nonstop. They would have been willing to exchange, ship a new puck etc. They went on and off the phone with me for an hour with me emailing pictures trying to figure out the problem and they were completely in the dark which leads me to believe that it was an isolated incident.
Dave,.
So, I finished my final interior render and thought I would share it with you. Amazing what you can do in a few hours of slacking at work. Its not professional quality but it gives a good idea.
This is the image I started with
This is the render
The only difference is I will have dual gagues on my A-pillar, boost and fuel pressure. The carbon fiber look is whats called di-noc, its a 3m carbon fiber vinyl that is very nice and used on some very high end cars.
Here is an example on a Bently
On the passenger side I mocked up a GM performance badge but I'm thinking of reusing the stock, the GM badge or a grand national badge, not sure yet.
The seats are black leather but they are actually GTO seats like these
I already have them and they are red but Ill be recovering them after mock up, not sure about embroidery, maybe a black grand national logo or gunmetal grey to be barely noticeable.
The door panels will stay stock with leather uppers matching the seats and insert in the rear, they will be black as well. I'm recarpeting the lower and keeping the concert sound pods on them.
very nice build, but 1 question, you are spending that kind of coin on a car & yet you are using those welfare Autometer gauges? there are much better & more accurate gauge options on the market.
You can load them directly to the site if you want so that none of the pics dissappear later also. I realized that if I put things on through photobucket they may end up missing so I started uploading directly so info wouldn't be missing if something happened later.![]()
Dave,
You might just need a longer test pipe! I had a customer here who ordered a downpipe from I think Southeast performance (no exactly sure) but the downpipe had the exact same problem where there was a large gap at the test pipe...I called the place and they said that we must have a problem with the exhaust and that it wasn't their parts... I had a Terry Houston test pipe sitting here and low and behold it fit Perfectly! The test pipe they included with the downpipe was way too short and since then I have Never delt with that company again...
Scot W.
This is an older thread where Carbon Fiber was used on the interior
http://www.turbobuick.com/forums/cars-sale/343933-87-gn-24-000-mi-show-car.html
Thanks Scot but its also at the incorrect angle. If the test pipe is longer it would try and go through the crossmember
