1987 Toyota Pickup Shortbed with 2JZ-GTE and TH400 fully built
-Tuned and currently running E85 Ethanol
-Precision 76MM
-Brian Crower camshafts 264/264
-Tial waste gate
-Tial blow off valve
-An extra Dummy BOV where the nitrous is fed.
-Custom 3 row aluminum radiator
-4" inter-cooler with 3" aluminum piping
-Custom one off stainless downpipe And exhaust all Stainless / and Vband easy removal.
-Custom Fuel Cell 10 Gallon with all braided lines
-Magnafuel Pump Custom mounted bracket
-Custom Hideaway Nitrous box hidden
-All AutoMeter gauges on a custom dash and AEM wide band
-TH400 fully built with reverse manual valve body with electric trans-brake- Valve body is also studded has billet internals. ATF plate Custom Bellhousing to mount up to the Chevy 400
-Cheetah Turbo Action Shifter
-Line Lock
-Custom New Driveshaft
-Custom Driveshaft loop
-8" Toyota rear end with 3.73 gears
-PTC N/L with all the goodies. Best of the best.
-Weld Wheels Draglites on drag radials
-New Brakes
-All original body and interior -2200 cc injectors custom fuel system with magnafuel in line fuel pump
-100 shot of nitrous to eliminate turbo lag and will turn off at 15 lbs pounds of boost with a optional manual override for just in case.
EMS Stinger 4 standalone, will sell with laptop and tuning software -and much more to list, over $30,000 invested without the labor
CUSTOM EVERYTHING the list goes on.
Easy Low 9's and there is def 8's in her. No Cage Street monster.
786-487-9775
18k
-Precision 76MM
-Tial waste gate
-Line Lock
-New Brakes
786-487-9775
18k
