I bought this car from a member on here a few years ago and it pains me to sell this, but the army is not done with me yet and has decided to move me again. I've owned the car for 3 years, and between 2 deployments to Afghanistan, have put just 600 miles on the car since. Previous owner did all the modifications minus the new tires I put on it and the Spal fans. It is a stock 71k original engine. Bolt on modifications include:
*Heavy duty rocker arm shafts
* Precision PT-6265 polished
*63 mm Precision exhaust housing
*84 lb Delphi injectors
*Modified ECM to run bigger injectors
*adjustable fuel regulator
*Red's volt booster
*Red's hotwire to fuel tank
*Red's Dual in tank fuel pumps
*New E-H pump assembly for brakes
*RJC power plate
*GN1 Performance Super Extreme front mount intercooler
*GN1 cold air intake with K&N filter
*Aluminum Radiator
*Dual Spal fans with Casper's Harness
*LC1 Wide Band
*Scanmaster
*Turbo Tweak adjustable chip for E-85 settings
*Janis Stage II transmission
*Hughes aluminum deep transmission pan with 700R4 filter
*HR parts trans mount
*PTC 3200 stall lock up converter
*New heavy duty U joints
*external transmission cooler
*ATR 3 inch down pipe
*ATR headers
*ATR exhaust
*ATR Pit Bull mufflers
*Dual air bags in rear springs
*Moog springs in rear
*Mickey Thompson tires with 600 miles on them.
The car is rust free and garage kept. It has one repaint from previous owner and would rate it a 9 , (a nick here and there from driving the car) and interior I would also rate as a 9 (needs new sunvisors) The car is set up on E-85 but have the chip to put it back to stock. Car is located in Clarksville, TN. I will answer any questions or get any additional photos wanted. Asking $16k Thanks.
*Red's volt booster
*RJC power plate
*Aluminum Radiator
*LC1 Wide Band
*Scanmaster
*ATR headers
*ATR exhaust
