how is the bottom end built, is it stock?, A little more info would be nice.. thanks
here is a better list..
Wheels & Tires
15x8 Weld DragLitesm w/ 27x11 Hoosier QuickTime Pro
15x3.5 Weld DragLites w/ 165r15 Metric Radials
also have stock t-type wheels
Interior
Custom Turbo 6 Logo Headrest covers
Custom Turbo 6 Logo Floormats
3-gauge A-Pillar Pod
2-gauge Console Pod
VDO Water Temp Gauge
VDO Oil Pressure Gauge
VDO Boost Gauge
Caspers Knock Gauge
Air/Fuel Gauge
5” AutoMeter Tach with Shift Light
JVC CD/Radio
Infinity 6x9 Speakers
6x9 adaptors
Engine
Eagle Forged Rods
Diamond Pistons
Champion CNC Ported Heads
Stainless Steel Valves
Comp “Beehive” Springs
Harland Sharp Roller Rockers
220/220 Roller Cam
Comp Roller Lifters
Champion Ported Intake
Accufab 70mm Plenum
Accufab 70mm Throttle Body
Cast Aluminum Tall Valve covers
Precision Front Mount Intercooler
3” Intercooler Piping
4” Intake Pipe
Precision GT6776BB Turbo
3” Stainless Steel Downpipe
3” Stainless “Singleshot” Exhaust
H&R Poly Motor Mounts
BigSuff3 Engine Management
Walbro 340 Fuel Pump
57lb injectors
Caspers Fuel Pump Hotwire kit
Razors Alky kit
Transmission
“Jimmys” Street/Strip Built 200-4R
Vigilanty 3500 Stall Torque Converter
Stage Right Trans Brake
Heavy Duty Drive Shaft
Rear End
superior axles
Eaton Posi Carrier
3.42 Ring & Pinion
T/A Aluminum Diff Cover
Suspension
Front Competition Engineering Adjustable Shocks
Rear Competition Engineering Adjustable Shocks
Alstons Adjustable Upper Rear Control Arms
Alstons Solid Lower Rear Control Arms
alstons braces
rear seat braces
replaced "lost" body bushings
Air Bag in Each Rear Spring
the car is all fresh.. less than 5000 miles on everything. origional body/paint/interior and it looks GREAT!
