1993 Rx-7 Montego Blue Touring automatic with clear title and just under 107,000 miles. I purchased the car 4 months ago with intentions to swap out the drivetrain but, my plans have changed. The car has been sitting in a garage since 01 because of a bad turbocharger. To get the car back into running order I changed the fuel pump and filter, battery and the ABS unit. The car runs really good, no check engine light and shifts nice and firm. The car has flat spots on the tires from sitting for a few years and will need a new set. The ABS light is on and will need a new wheel sensor and the Airbag light just came on due to a faulty clock spring. New clock spring will be included with the car. The interior is in good shape with minor wear on the driver seat and your typical cheap Mazda plastic problems. The pull on the drivers door is cracked and willl likely need to be replaced. The body of the car has typical dings and a few small dents and scratches. The headlight covers will need to be replaced. Overall the paint shines and looks good for a daily driver. The car is a very good canidate for a swap or with some minor work become a nice daily driver.
Car is located in Jacksonville, Florida....asking $7800.
