Trannyman95
- Aug 12, 2007
Hey guys, I havent been on many forums for a while due to being swamped with work and family stuff going on but moved into a new location early last summer so I got to work on some custom projects when time permitted and finally got a supercharged top swap setup on a 99 Firebird. I also posted this on a few other forums but wanted to share on here as well. The car belongs to a good friend and has been bugging me for the past few years but I didnt have the space to commit the project since I planned to take a lot of time to do things right and make more down the road..... After doing this project and having things buttoned up Im not sure it is honestly worth the trouble due to the extensive time involved and the expense. Its not just a simple top swap by any means and I give a lot of credit to the guys that have attempted this project! The firewall was not modified in any way for this project and that was the goal. The AC and ABS are still in tact as well. I made custom trolleys for the engine and trans and dropped everything out the bottom and rolled it out as this made it much easier to freshin things up and reseal the badly leaking engine. I used L32 fuel rails and since this fuel rail is for a returnless system an L67 fuel rail regularor and tubing was used and plumbed into the fuel lines under the hood. There is a whole lot more I could talk about but wanted to share a bit of what I did for now. The car is running and has a rough starting point tune on it but it has snowed here all week so I havent been able to drive it yet and the roads arent the best here, nor are the tires on the car so I cant report with its performance yet but already doing a rwd L67 swap in my 86 Cutlass produced pretty awesome results for what I worked with engine wise. This engine is still the stock lower L36, L67 heads that were rebuilt, S1X blower cam, Pacesetter headers with 3" catback, and of course extensive blower work and port job. Excuse the stock drive by wire throttle body that is currently on the car, my plans took a huge turn south after diving into wiring as this setup was intended for an LS1 throttle body. When spring time rolls around the throttle body will be swapped out with a larger one from a truck and the supercharger pulley will be dropped, this is just starting point stuff on the car for now. I have tons of pics but pulled a few of the nicer ones to share online. Enjoy!
