Lee Thompson
- May 24, 2001
#1-- Any reason I can/t take any governor, Use a set of gram scales, and mill the weights down to the same weight as the brf, Install the correct blue brf spring, correct drive gear and have a brf gov?
#2-- use this gov. a cz vb. and a Superior Super Servo and have a trans that will work behind my turbo motor.
I/m not opposed to going into the vb to change shift points.
Thanks in advance
Thanks in advance
