2 standard cranks + ls1 ported/polished heads
87buickracer
1)I have a standard/standard turbo crankshaft from a 30k mileage gn.It has the rolled fillets on the main and rod journals..A rare find for a crankshaft with this mileage..Crank is in machine shop being polished..specs is 2.500" on mains and 2.250" on rods..will have picture of gn crank up by weekend..
price is $400.00 firm plus shipping in u.s
2)I have standard/standard ls1 crankshaft with low miles..Just needs to be clean and polished.If you would like to have it clean and polished I could also have that done for additional charge.price is $175.00 plus shipping in u.s
3)I have for sale a beautiful pair of competition ported and polished LS1 heads with dual crane cam springs(#144832-16)bigger valves(will check size) and valve job rated for .600 lift cam.These heads are set up for .600 lift cam and have a flow sheet from central fl machine and speed.. At .600 lift these heads flowed 265 / 207 ,@ 298 and 315..Also included is the stock LS1 cam,springs and SLP zo6 maf sensor..
price is $1,495.00 obo plus shipping in u.s)
I accept money orders and western union payments at this time..thanks..
2 cranks + ls1 pp heads
pictures--
20/20 crankshaft
4)I also have a freshly polished 20/20 turbo crank for grand national,ready to drop in and go.price is $200.00 plus shpping in u.s
fmic
5)I have a front mount intercooler for sale.This unit comes from isuzu npr truck and works well on the grand national..This is a well built piece and retail somewhere around $900.00 new..Great for hybrid build or someone who wants to save a few bucks on a front mount..price is $200.00 plus shipping in u.s
standard/standard turbo crank 30k miles(rolled fillets)
pictures---:)
fyi:For the hard core racers using girdle or caps this crank is perfect and on the low side...
Ls1 injectors 30k miles
6)I have a set of ls1 injectors with 30k miles out of a 2002 corvette..Injectors were replaced when up-grading to magna charger supercharged kit..listed is numbers off both sides of injector.
side1)12561462..................side2)0280155931
all injectors have the same number on both sides..
price is $200.00 shipped in u.s
a/c delete plate
7)I have a very nice gloss black a/c delete plate,brand new in the bag...price is $75.00 plus shipping in u.s
note:both sides is gloss black..
Rjc girdle kit
8)Rjc girdle with crank scraper and arp hardware kit
crank scraper is notched for stock rods with arp bolts.......
not sure if I'm going to sell this yet,but testing the waters.:biggrin::biggrin:
40 over hyper pistons
9)I have a set of 40 over hyperuetetic pistons.These pistons have about 7k miles on them..I switched to forged along time ago and these have been in the box for a while.They were purchased from poston's enterprise.price is $125.00 plus shipping in u.s
Price on the RJC Girdle? everything included I assume? (shims, all hardware, any broken rail studs?) Also assuming it is a 20 bolt for a 109...
Rjc girdle kit
Im also interested in buying the rjc girdle if DOUBLED dosen't get it.
rjc girdle
If i decide to sell I will post price..Thanks for the interest...
Brand new B+M shift cable
10)I have a brand new b+m shift cable for sale.will add part number and length later today..price is $60.00 shipped in u.s
LS1 ported/polish heads and maf price reduction
The price on the ls1 ported/polished heads with flow sheet and ls1 (slp)maf sensor has been reduced to $1,200.00 plus shipping in u,s
note--
At this price these heads are a steal because they flow more than edlebrocks ls1 heads.retail is around $2,500.00,so for $1,200.00 this is a 50% discount..
Once you see these heads in person you will see what I mean,and I'm giving you the SLP ls1 maf sensor for free..
Brand new Cat girdle with hardware
11)I have a brand new cat girdle with hardware.I test fit it on block and all the holes line up.Just replace the cat studs with arp ones and open up the oil drain holes in front and rear of the girdle..I was keeping this for another motor but decided to sell it..price is $275.00 plus shipping in u.s
