- Nov 30, 2009
I'm looking forward to improving my 1.6 60ft with the 2-step .That is exactly what I did. Momentary switch on the lower left corner of the pedal. Ad long as you don't drive 2 footed normally, you won't ever activate the switch. My Boost Leash takes care of the launch boost From the same switch. Creep into the staging hot and when you get the second bulb , masj the gas pedal to the floor. As soon as I let off of the brake, the 2 step stops and the launch boost lets go...
So far I have been able to cut a 1.46 60 at 5 psi. When I get the tune dialed in to where the Alky isn't coming on so hard at 6 psi , I will see how it launches at 10 psi.
Bryan
