turbo96max
- Jun 6, 2007
bouncy 18-20 psi on 16 psi Spring Press when using TC compressor as source on the boost gauge, but according to fuel psi , its a steady 20 psi ,, anyhow, i changed the vac source to a port on the dog house and got the steady 16 psi which is the spring pressure.
any idea why the difference? i had the vac line from the tc cover, to the bottom of the gate, and nothing to the top. same as i do now, just vac source is from the intake...
what do you guys think about the way the return dumps back into the dp. i personally didnt like it, i would have made it with a much better angle for better flow, but i dont have a welder or the equipment and paid a shop to do it, the guy swears it wont cause backpressure issues controlling boost of he will redo it... i guess i can live w it if it functions properly,, so far it holds 16 psi nicely
