CreepinDeth
- Feb 8, 2011
Got everything out of my 200-4R except the part that needs the special Low/Reverse clutch tool. The last part I got out was the sun gear shell and sun gear. Basically I'm at Row C all the way to the right of this diagram. http://www.bulkpart.com/Merchant2/graphics/Catalog-pdf/200-4R.pdf
I have a yoke attached to my rear shaft, and I can't get it off.
Did I miss something or shouldn't the yoke just come off the output shaft at any point in time ??
The shaft moves but is locking up against something too.....thought it would fall out at this point in the dis-assembly.
I can't use the special tool until I can get this shaft out of my way.
What am I possibly facing here as far as the reason ??
Also besides having to buy this Low / Reverse tool for $99 for one time use,
what have you guys done to remove this part without buying this tool ??
