2004 4R 'BRF' out of a 1987 Buick G/N
I have the tranny still in the car,if you live local come and drive it.
My reason for selling it is because about 1 month ago i took my car to a tranny shop just to have it serviced,they replaced the filter/fluid for $193.00
Everything was ok and then 4 days later i went to pass a car when i was driving about 45mph,then the tranny kicked down to second gear and just flashed NO More tranny
I remove the tranny and found that the stator support was stripped.
So i relaced the pump/hardened stator support,and replced the converter and filter/fluids
Now the car slips into 2nd and the same with 3rd,but it goes into 4th normally.
Under wot the car hangs up 1st to second and i have no idea about going into 3rd because i take my foot out of it.
I have decided to just replace the tranny.
Im located about 30 minutes north east of Orlando
I still have the original Converter and pump,i never swapped over the springs when i put in the new pump <maybe i should have>
$500.00 local pick up preferred
