2004-R street-strip trans with brake
brian
Senior Member
I am relisting this with a new price.
The trans is totally fresh with all the necessary good internal parts to run into the 10`s. It is a Monte SS core that has been modded to GN BRF standards.
Special inside, is the drum has been welded, and heat treated to prevent breakage. All extra clutches,hardened stator, 10 vane pump, pump ring kit, 550 and 400 boost valves, and manual transbrake. The trans also has one of the new "case stretcher servos" in it. (info can be seen in the feedback section) This trans is set up for a lock up converter and will shift quite nicely. You will not be dissapointed with the shift quality. :-) Price is $1200, which is a screaming deal for a trans with this much inside it.
No core needed back, but I will take one if you like. Prefer a local sale, but will ship anywhere. Buyer pays full shipping on this.
Thanks,
Brian Hofer
