2004r And 3500stall 9.5" Pi Convert For Sale
8urV8
Hey guys up for grabs is a brand new 2004r(LOCK UP)Transmission built by Brian Hofer and 3500 STALL 9.5" Vigilante convertor.Building the car right now almost done but I'm going a different route to a turbo 400.Here is the trans info:
A Monte SS CZ(Model)Bigger boost valves,pump ring kit,alto direct clutches(extra throughout)and Red band with shift calibration(shift kit).Lock up with a 694 servo and transbrake.The input shaft and drum are hardened.The trans will have quick shifts at part throttle and firm(not harsh)at WOT.
Difference from this and a BRF is a later WOT upshift 5250 VS. 5500,and a slightly earlier thirdgear while driving.
The trans is setup to run low 11's and to high 10's.The trans is to be used with any higher stall convertor,and a reinstalled stock one is okay to use.Daily driving is not a problem.
SINGLE DISC LOCK UP CONVERTER
THE 9.5" VIGALANTE FEATURES:
H. D. Lock-Up Clutch
A Unique Billet Front Cover
4130 CNC Machined Turbine Hub
Sealed Torrington Bearings
Furnace Brazed Impeller & Turbine
Anti-Balloning Plate
Reinforced Turbine Vanes
Heat Treated Precision Hubs
Electronically Balanced
Pressure Tested
$2100 for combo.I like to sale it locally or can ship out buyer pays for shipping.Have great feedback here so no worries here.
Thanks,
Eric
man! y cant this be for sale after the holidays (during which my tranny will probably go):eek:
good luck with the sale, prolly will go fast.
buickbert
