2004r brf spiting fluid from some unknown place
jimski
In over my head
Why does it spit fluid when i overdrive it on the highway,nothing is leaking around the pan or anythingThe unit is completly sealed up ,where is it coming from,my only guess would be the blow hole in the top.The fluid level is proper too. Man the smoke this thing produces when the fluid hits the exhaust pipe is extremly annoying and stinky.When i do not push it is fine.This just started happening any input would be apreciated.
I HAVE seen this on two different cars, and in both cases it was a cracked tv cable. Every time i would hit the gas pedal, the tv cable would bend out of shape and piss fluid. hth
The converter clutch solenoid is not locking up and the trans is getting hot and spitting out the vent. Straight to the exhaust piping and then you see the smoke. What ever the reason, it is getting hot and puking out fluid. I just went thru this 3 weeks ago and the whole bottom of the car is covered in fluid yet the level is perfect. Doesn't take much to make a mess with trans fluid.
The cable is in perfect shape ,that was first thing i checked.
I think this may be my troubles after searching around for answers,I do not think it is getting hot thou, i have a trans cooler with the fan on it.Im gonna check the wire for 12v it may have blown a fuse or something thanks for youre help
