Here is an easy bottom 10 high 9 second capable 2004R.
Currently set up as a lock up, but, could easily be changed to a non lock.
$2450 outright shipped to you (cont U.S.). Look around and compare prices, this is a great deal with a real CZ core included. Or $2700 with a deep sheet metal pan installed.
1 year warranty.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
This trans features:
Billet forward drum
Billet input shaft
Billet anchor pin
Aluminum direct clutch apply ring
Transbrake
"Case Stretcher" servo
Alto wide band
7 directs
5 forwards > clutch packs
3 clutch OD
Rollerized pump, low roller, drum, center support
upgraded TCC switch
new pressure switches
higher pressure spring
rev kit
550 and 400 boosters
hardened stator support
resurfaced pump
all new bushings and bearings
AND MORE
1 year warranty.
Billet forward drum
Billet input shaft
Billet anchor pin
Transbrake
Alto wide band
7 directs
3 clutch OD
upgraded TCC switch
rev kit
resurfaced pump
AND MORE
