D.PHILLIPS
- Oct 18, 2007
I have a 2004R transmission in my 57 chevy with KTF on the transmission plate. Can you tell me what this transmission was used in. Thanks.
SignUp Now!I'd like a better description of the symptoms. Have you dropped the pan and inspected the gov and its bits? Sounds more like the shift timing is goofed up. Has the unit been worked on?I think the governor is bad in mine as I have to shift 1 to 2 manually or it bogs going to second.
