TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Doing a conversion to an electric fan for my stock location intercooler and have a thread going on the turbo section of the board. One member suggested tying into the plug on the trans for 3rd gear. Was going to use a window switch but this sounded like a less complicated way of doing it. Want the fan to shut off once the car is up to speed and I am assuming that the 3rd gear switch is always grounded in 1st & 2nd? So when the trans shifts into Drive the switch opens? I was going to connect the ground wire from the relay I am using to that wire. OK to do?
One thing I was wondering is what happens when the trans shifts to overdrive? Will the 3rd gear switch remain open?? Don't want the fan coming on in in Drive OR Overdrive. thanks for any advice.:smile:
