2004R with CZ v-b and billet drum w/brake
brian
Senior Member
CZ MonteSS valvebody trans, ready to ship and fully tested. You can do a search in the trans area on CZ v-b`s. They are a very nice set up in a GN with ported heads and a cam upgrade. This trans will upshift at WOT right around 5500-5600.
This unit also has all the correct wiring for a GN.
Billet drum, heat treated input shaft, rollerized gear train, custom servo, and trans brake. This is a lock up trans and has a Hughes deep cast aluminum pan.
The unit also has 555 and 405 boost valves, 10 vane pump, rev kit, Alto wide red band, billet anchor pin, and extra clutches throughout. This is a fully capable easy mid 10 second trans.
$1850 with core included + $150 shipping.
Feedback can be viewed in the feedback area. Search under, brian or Brian Hofer.
Thank you very much...
Brian hipsibri@cs.com
