Aug 6, 2009 #1 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 does the pump bolts go into blind holes like head bolts do? mine are leaking fluid. do i need to use sealer on the threads?
Aug 6, 2009 #2 S Steve V Steve V's Automotive 757 560 2782 Joined Jan 5, 2004 Messages 4,376 There's a washer that goes under the bolt head it's soft metal with a rubber like coating. That's how it seals. They go into blind holes. I also seen some builders use RTV under the bolt heads. I do not.
Aug 6, 2009 #3 L Lee Thompson New Member Joined May 24, 2001 Messages 3,184 leak 4L60E uses the same bolt only it has an o-ring under the head. No more leaks!!!!!
Aug 11, 2009 #4 M mybuick intercooled engines rule! Joined Jul 21, 2002 Messages 1,502 would you happen to have the gm part number for the bolt cuz the parts counter guy is playing stupid.
Aug 11, 2009 #5 S SSedan64 JoaTMoN Joined Dec 8, 2007 Messages 1,590 This is what I found, may help. From a Large trans catalog. Part#74312A --Pump Bolt O-Ring, 87-up Reference#8654341 http://www.makcotransmissionparts.com/74312A.html Part#74777AK--Bolt Set, Pump to Case (O-Ring Type) 86-up, No Reference# May have to get the bolts from a trans shop. About 47Mb. http://dnlfiles.bf2guru.com/Ebay/PARTS CATALOG.pdf
