ok my stock trans is junk ,so i bought this stage 2 ck trans so i was told...Trans shift fine other then WOT,So I was told tv valve limit spring i believe is my problem.So I drop the pan on old trans that i know is a brf valve body,so i could look at it,and kind of compare some different things with new one.Here is what i found below
old trans known brf valve body says
1 br3 on valve body in white lettering,
2 number stamped on valve body 4203 D-7
3 gear for speedo blue and other gear orange
Stage 2 supposed valve body says
1 C something 6 in white lettering
2 number stamped on valve body 4203 D-9
3 Black speedo gear and other gear green
other difference found
sping and cup in on taller and stiffer here are some pics of what different just from quick inspect....
parts on left in pic are in stage 2 pics right old brf trans
