2010 TSO Top Gun Point Series Rules
turbobuick
Staff member
This is the tentative set of rules for 2010. I will leave discussions open till the end of the January. All opinions are welcome BUT final say will be given to those that have raced the class. No changes have been made from last year.
2010 Rules:
Racing Rules:
INTENT: This a heads up class for 81-87 Buick regal bodied cars running single turbo Buick V6 engines and stock style rear suspension with a 10.5" tire. The class is to be run on a .400 pro-tree and on a pro-ladder, no 1st round mechanical or no show bye runs. All cars must have all applicable safety equipment for speeds obtained and must be able to pass host track safety tech. All entrants SHOULD have the necessary equipment to be able to run faster than 9.99. Host track safety tech will make all decisions concerning safety tech of vehicles competing in the TSO top Gun Point Series and it is the drivers responsibility to make sure their car meets ALL host track requirements.
Class minimum weight is 3200#
1. BODY: 1981-1987 Regal body required with stock firewall location and full stock frame with stock wheelbase required (108.0" measured). Frame modifications for roll cages, safety, tire size and cross member clearance are allowed. Frame notching for tire clearance is allowed but the inner frame rail can not be modified or moved from its stock location. Four functioning headlights and taillights required. Light weight aftermarket body panels allowed. No pin on doors or front ends allowed. Doors must have door panels and be functional with functional windows allowed.
2. EXHAUST: No part of turbo exhaust may exit forward of engine flywheel area and a muffler is required.
3. FRONT SUSPENSION: Must have stock mounting locations. Any aftermarket bolt on part is allowed. Rack and pinion conversions are allowed. NO SPINDLE MOUNT WHEELS ALLOWED
4. REAR SUSPENSION: must maintain factory mounting locations on the frame. Coil over conversion allowed, sway bar and panhard bar modifications are allowed. Must maintain factory 4-link arrangement. Any automotive type solid axle housing allowed.
5. TIRES: Rear tires may either be DOT-approved and labeled or labeled for racing slicks. DOT tires must have labels facing the outside of the body and are limited to a maximum new tread width of 12.1 inches and can never exceed 12.25 inches in width. Slicks are limited to a maximum sidewall designation of 10.5 inches width and may never exceed 11.1 inches in width. No drive tire may have sidewall designation height greater than 29.5 inches. The front tires are limited to 4.5- inch minimum tread width. The tread of tires must not protrude outside of the exterior of bodyline at top of tires.
** Measurement will be taken with tape measure from end of tread to end of tread.
(This dose not allow the MT 29.5x10.5W)
6. TURBO: Maximum compressor wheel size is 88.0 mm /3.464” - inducer wheel diameter and exducer diameter of 127mm/5.000". A maximum tubine exducer diameter of 93mm/3.66". Inlet housing is permitted a maximum inlet diameter of 3.544”where the leading edge of the compressor wheel meets the housing. Turbos with compressor wheel inducer diameters of 82mm and smaller will have no limit on compressor exducer size and turbine size. Large frame thumper series turbos are not allowed in any configuration. Turbine and compressor housings must carry a manufacturer part number that is readily available to the general public prior to Jan1 of the current race season.
Compressor wheel to housing clearance must maintain a maximum of 0.080” clearance beginning from a) where the leading edge of the compressor wheel meets the inlet of the compressor housing to b) the transition point where the trailing edge of the compressor wheel meets the volute. All air entering the turbocharger must pass through the turbocharger inlet. Injection of any liquid, gas, or any other substance into the inlet or exhaust housing prohibited. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic material wheels prohibited. The tips of the impeller wheel may not be stepped, cut down, or notched to meet impeller tip-to-tip dimension. (.500-inch will define the tip of the impeller wheel).
Turbo must be located within the factory engine compartment with stock turbo orientation. The turbo must not be mounted forward of the factory core support and the inlet has to be facing the drivers side of the car and mounted as close to the stock location as possible. The crossover pipe can be in any location.
Any competitor is subject to inspection and removal of compressor housing. If protested by another competitor, the protesting competitor is required to put up $100 which will be given up if the turbo is found to be legal. Anyone found to be illegal or unwilling to remove the compressor cover for inspection will be automatically dis-qualified and removed from the point series.
7. TRANSMISSION: Any GM automatic transmission w/ any torque converter allowed. No Lenco, Liberty or manual transmissions with or without clutch allowed.
8. FUEL: Gasoline fuel only, no additives, alcohol, or nitrous oxide injection allowed. No additional injection/spray of any sort in or on the motor, turbo, IC, drive train etc. NOS bottle(s) shall not be on vehicle during competition or qualifying.
9. Interior: Stock appearing dashboard and passenger seat required, door panels required, interior must be carpeted and as close to factory appearing as possible. Rear seat may be removed, but area shall be carpeted.
WEIGHTS:
3300# for any turbo up to an 82mm
3400# for a 83mm to an 88mm turbo
** All weights will have a five pound error factor for scale inconsistency
ADDITIONS:
-50# for compressor cover larger than H cover on 83mm and larger turbos
-100# for any turbine housing flange other than a T4 on turbos larger than 82mm on Stage 2 head cars
-100# for a liquid IC
Deductions:
-100# for production style heads
I would like to see the weights reduced we all Race at our local tracks and because of the V6 we get weight breaks anywere from 2800 - 3300 LBS. It does not make alot of sense to have to add 200-400 pounds to race TSO, for the most part we are the fastest buicks at an event but yet we carry alot of weight.
