4.5 is OK for the front, but 5.5 is too much for the back, the wheel will be against the frame, unless the frame is notched. 4.75, 4.875, are better, or 5 (then use a thin spacer for final adjustment if needed)
You really need to measure to be sure when you are going that big.
