You will need a distributor drive gear, eccentric eliminator, thrust bearing, thrust washer, key and cam bolt button. Dan at DLS has everything you need or weber cams. All billet cams I've seen do not include any of this hardware and the cams new go for $450. You are looking at $150-$250 for all the nose hardware
