215-70-15 fronts
shifty6
Anybody run em? I'm looking to use them w/a 6" X 3.5 bs wheel on a stock brake/front susp. (except for a big swaybar) set-up...will the increased dia.(26.9") cause any rubbing issues? Any input/experiences would be appreciated.
Im running a little over 26in. tall fronts on 15x6's 3.5bs. Not close to rubbing anywhere
Thanx for the response....are you running 205-70-15's(26.3" dia.)? I'm wanting to take out the "raked" look from the 275-60's out back. TIA.
Yea im about 26.3 ish with 28' dr's out back . Sits right
Thank you.....looks like I'll be doin the same as you did then.....def don't want any rubbin. Just thought the additional hieght of the 215's MAY have been alright on a narrower 6" rim. Thanx again for your help:cool:
I have kuhmos 215x70x15s on front with 6" rims& 275x60x15s mrs on back-no problem!
I have kumho 205/75/15's on 3.5 1 peice welds an it makes the car sit level with 275/60/15's on the back no rubbing issue the tire is aprox 27 inches tall
they will fit wider fronts but this might be where yall are having issues runing them
That's exactly what I was thinking....7" wheel and they prolly would have rubbing issues and is why I got the 6" fronts. Glad to hear that you've provided another tire size option that works:biggrin:
