22526178 GM 8.5 Axel Bushings
I belive I have a set of aftermarket polys if interested
88hurstolds, Do you have a good GM dealer you can work with and have them do a dealer locate for that part #. They should be able to check for new old stock at all the dealers around the country.
I have a guy in FL, he says that most if not everything older than 25 years is not even in the system IIRC.
I'll ask him for clarification on that...
Why don't you use the Moog K-6178 bushings? I assume you are talking about the bushings that press into the ears on the 8.5" housing.
