I made it to E-town tonight. My first attempt a few weeks ago yielded me a 13.4@100mph on a 1.92 60ft.
Tonight, the air was good. The only change to the car was a test pipe. Boost was unchanged and remained at 17psi on every pass. O2's are getting borderline with the test pipe at 750mV, KR is 0.9 max.
First pass...launched at 4psi, locked the convertor a split second after the 2-3 shift....
60ft. 1.845
330' 5.397
1/8 8.441
mph 80.82
1000' 11.045
1/4 13.243
mph 102.47
Second pass...launched at 5psi, locked convertor at same time as 1st pass
60ft. 1.776 - BAM!
330' 5.266
1/8 8.246
mph 82.30
1000' 10.818
1/4 12.998
mph 103.25
Third pass...launched at 6psi, slight push at line before launch, locked convertor same as other passes
60ft. 1.865
330' 5.369
1/8 8.355
mph 82.17
1000' 10.932
1/4 13.114
mph 103.22
Fourth pass..., locked the convertor at the line, staged at 5psi, launched (cut a .525 light) and BOOM! After a loud bang, the tranny started slipping very badly. I got it down the track, and into the pits. I tried to nurse it home, but after a few miles, I had it flatbedded to my house. There is about 3" of slack in the detent cable at the throttle body...could this have broken? Input shaft? I dunno'...
Anyway...it's kind of a bummer. I had let the car cool off for a few extra minutes on this last pass, and I went back to a 5psi launch. I think another .05 off my short times and I might see a 12.8.
Mods are as follow...
*Cottons 93 chip
*Postons air box base lid
*Billet inlet bell
*Convertor and fan switches
*160* stat
*Walbro 340 with hotwire kit
*Adjutable wastegate actuator...running 17psi of boost
*Test pipe
*235-60/15 DR's
I now need an adjustable FPR (or put on the 237 in my toolbox
) and I have an RJC Powerplate. IMO, a little more fuel, the Powerplate and 19-20psi of boost and this thing would run a 12.5...if I get the tranny woes fixed.
S.
60ft. 1.845
330' 5.397
1/8 8.441
mph 80.82
1000' 11.045
1/4 13.243
mph 102.47
60ft. 1.776 - BAM!
330' 5.266
1/8 8.246
mph 82.30
1000' 10.818
1/4 12.998
mph 103.25
60ft. 1.865
330' 5.369
1/8 8.355
mph 82.17
1000' 10.932
1/4 13.114
mph 103.22
*Cottons 93 chip
*Billet inlet bell
*160* stat
*Test pipe
*235-60/15 DR's
S.
