Ok guys, I'm debating whether or not to tackle a 3.5" downpipe or not. I'm running a 252 c.i. Stage 2 GN1 headed motor. Everything is not together yet so I cant tell you what I'll be getting out of the motor. The car will be set up for E85 with 160lb injectors and will be running a FAST XFI management system once the money comes in. When the motor is in, I'll be putting the 60# inj. back in and running my TT chip for now. I have a Precision 70BB turbo. I'm also running TA headers and AC. I have an internally gated 3" downpipe right now. I'm having a hard time deciding which route I want to go with the down pipe though. I'd like to run an external gate to try to eliminate creep the best I can. I'm having a hard time finding a down pipe in 3.5" and I know it will be a nightmare trying to fit it with the AC. Should I keep this downpipe and use it? Or should I try to build my own 3.5" and use the gate port in the header for external gates? What would you do? thanks for the opinions! -----Jeremy
