3.625 Stroke Crank
Trbobuick
Boost addict
hello all,
a 3.625 crank and a 6.2 rod will clear the stock block correct?
thanx
brian
Highly likely that there will be an issue at the oil pick up boss in a stock block.:(
hmmm.....what mod would need to be done? ill have to dig out the power source book tonight and look.
Brian
I would think that the area would be pluged and milled off. Tis is why most stage 2 blocks have a pick up boss cast in front of the block right behind and to the side of the #1 cap.You can see this on my stage 2 4.1 off center blockin the lower left side of the pic
