3.8, 85 block, 87 configuration
Rob_85Ttype
This is an 85 motor, 35000 original miles, but it had a cam bearing failure early on. It has been taken apart, cleaned, and rebuilt by me...by far, not my first engine. It was honed, and original pistons reused. It has a 208 modern muscle car cam inside. Everything inside is refreshed, bearings, seals, crank cut, gaskets, new timing cover, new water pump. It has steel shim headgaskets which is correct to maintain proper compression ratio for 85, which is equivalent to 86-87. It has been drilled and tapped for the 87 turbo oil return line. It is for sale as you see it. It has China made headers that copy arizongn, and I reworked those to make them fit better. It has not been cranked or broken in. I want 1500.
o_O
