3bar replacemnet map sensors for the TTA required the power and ground to be flipped for use in a TTA because the original TTA 3bar was reversed as was the wiring , not sure how you would have even get ahold of one of those original TTA sensors
like posted all it does is drive the stock boost gauge and nothing else unless you run one of the following:
(A) razor alky injection
(b) fast, XFI, big stuff 3 or a tt sd chip
(c) datalogger like powerlogger to log boost over 15psi
(d) a new electronic boost gauge
for stock application the 3bar does absolutely nothing better for the car vs. the stock 2bar other than make the stock analog dash LED boost gauge read incorrect
and its not connected to the ecm so it cant have any effect on its operation
