3 bar map sensor???
TMGN
Installing FAST and putting a 3 bar map sensor on.Do I need the new pigtail wiring connector or will this just plug right in?Thanks Tony
I had to put in a three bar map into my 85GN when I installed Alky. Direct replacement. Brad
You can plug it in as a direct replacement, and buy a Caspers adapter for the FAST to tie in at the factory white/black connector which is located above the ECM. If you choose, you can relocate the MAP above the ECM and plug it in directly sans the adapter. HTH, Brian
