Chaotic GN 85
- Mar 15, 2008
Im having trouble finding these connectors for the 3 bar map sensor. Are all of the connections the same for the 85 GN models as the 87 Digital Dash?
SignUp Now!Im having trouble finding these connectors for the 3 bar map sensor. Are all of the connections the same for the 85 GN models as the 87 Digital Dash?![]()
heres diagrams to help clear any confusion as to what connectors you need to find to make the jump and where they are in the car
im getting 2.25 v at my map sensor (center) grn wire. key on engine off. and my analog dash boost gauge (stock) has always been off, it says im at 6lbs of boost at idle and when i hit gas it max's out. i have an auto meter boost gauge on A-pillar for accurate readings. is my map sensor bad?
how do i know the diff between 2bar or 3bar? plz
im really bad at explaining myself in detail. :redface: what i meant was how do i know then if i have a bad 3 bar or a good 2 bar? is there any numbers on the exterior of the sensor that will tell me?
