My motor is stock 104,000 mile "bolt ons only" motor. I did take the valve covers off to install new valve springs with the heads still on the motor. BTW if your valve springs are weak this is a good investment.
Now Rodger's motor was a typical higher end stock block build up. he had GN1 heads, 210 roller, j&e's, billet center main caps, stock rods and crank, atr headers, FAST fuel managment system, PTE front mount, ect..
The point I was trying to make is that even though Rodger's set up had all the things associated with "more lag" he still spooled better than me do to having a motor that was able to flow enough air to spool a turbo of that size properly.
Hope this helps and good luck with your set up: Jason
