3" dp 4 tta
JP112_89
I want to thank Phil (pdzz). He is honest and best performance mechanic in our area period. Thanks again Phil Bassage.
Purchased the DP off Jim Dunn. Second custom piece I have purchased from Jim. Always had exceptional service from Jim and he a great guy.
Phil and I were amazed on how perfect the DP fit. A work of art for sure. I noticed faster spool up over the 2.5 DP and NO boost spike or creep.
Looks great Joe. How did it fit? Also I do not see a O2 bung!!! :p
Thanks Steve! Fit's awesome for sure:cool: Once we removed the crossover pipe, the DP bolted right up without clearance issues. Plenty of distance between the DP and exhaust manifold as well. I did not use the 3" test pipe/dump that came with the DP. The pipe came with a 4 bolt flange...I have the 2 bolt flange on my 4" intermediate pipe. So we reused my 3" test pipe a band clamp( 3 came with the kit). Actually, I didn't want to use that dump pipe since I have a 4" cat back. Plus, my test pipe was previously painted with 3M weld thru primer:) so that worked out great.
The whole project took 1 hour 45 minutes and that included doing an inside radius job inside the exhaust housing.
Bung is going in the test pipe next weekend.
