Bolts that I recommend are Stainless Steel Hex head cap screws that are 8mm x 1.25 thread and 30mm long threads. (see pic) You will also need M8 washers to go with them 4 of each and a 6mm hex key.
McMaster Carr p/n 91292A149 in 18-8 SS work the best.
Ace Hardware will have them as well in their bolt section. You want too look for the Metric SS pull out drawer section that has all the hex head cap screws.
These are the type of bolts you're looking for.
The install is simple, just use the cork screw method and rotate the new pipe into the spot in a clock wise twisting motion. Remove the stock pipe by twisting it out counter clock wise, and install the new clock wise. You'll see, it's actually very easy to install once you get the spin just right. You might have to cut off the stock cat and or test pipe if it's froze to the downpipe as it's almost impossible to take off both without the car being jacked way high in the air.
Removal of the stock pipe is easy. Just unbolt the two spring loaded bolts that connect the stock downpipe to the cast iron 90* elbow. Once it's out of the car, spray the 4 bolts that attached the elbow to the side of the turbochargers turbine housing and let them soak for a few hours. While the PB blaster is setting in on those bolts, use a small flat blade screw driver, or a small pair of needle nose pliers and remove the E-clip that retains the wastegate actuator rod onto the wastegate swing valve arm.
Don't worry if it goes flying across the garage never to be found again, we have a better solution. Now, remove those 4 bolts and pull the elbow off the turbo, being careful not to break them. Clean the flange surface of the turbine housing with either sandpaper and cleaner, or a strong cleaner with lint free rags, making sure not to get any grit or trash into the and or on the turbine wheel. Using shop air to blow out all the crud/trash really helps here. Install new downpipe, use Copper High Temp Silicone to help seal the downpipe to the side of the turbine housing. Put antiseeze on all the bolts with washers, and screw them all in by hand while holding onto the downpipe and moving it around to help align the bolts, before putting a wrench to them. Once all 4 are installed, you will see that you will be able to move the downpipe around slightly. This is to help gain clearance on items such as the frame rail, the header, and the heater boxs' heat shield. Once you are happy with the clearance, tighten up all 4 bolts good and hand tight with the 6mm hex wrench. Hook up your wastegate actuator rod and either use an ID badge clip, an alligator clip, or one of the cruise control cable retaining clips to keep the actuator rod onto the downpipes swing valve arm. Don't try to reuse the Oh Jesus E clip that is on there stock. It will just lead to way too much frustration when it comes time to adjust the actuator rod and or remove it in the future. From here's it's just hook up your cat or test pipe and you're good.
A 3" terry houston style downpipe, even on a bone stock car, will yield 10-20 hp and you will definitely be able to feel the power, with decreased spool up time from a punch. There is a template over on
Turbo Regal Web Site that you can print out and use to cut your heat shield. I have seen some people who just bend the shield to clear the pipe vs cutting it, but the shield would still be resting on the pipe. It's best to cut it too fit.
Hope some of this helps.
Patrick
