Race Jace said:
You also can just look at simple fluid dynamics and pressure shape loss. You have to understand what is happening when the exhaust exits the turbo and obviously some people that posted here do not. Scavenge pulse out of the turbo? Pipe diameter affecting temperature? there is so much misinformation in this post i don't even know where to begin....
There is no scavenge pulse out of the turbo. Whatever that is..There are resonant pulses in the piping itself, which help a great deal to scavenge the gases. Too much area and this pulse will slowed way down to the point of uselessness. When a pressure wave reaches a larger cross sectional area, it will reverse its sign (positive becomes negative, and negative becomes positive) and its direction. This is "reflection". The positive wave travelling towards the end of the pipe, and the negative wave travelling towards the turbine will propel exhaust gasses towards the end of the exhaust system. If the diameter of this pipe is 3 meters wide, the intensity of this pressure wave and reflection is very low. Pressure shape loss? Is this like nookular weapons?
Yes...pipe diameter affects temperature. Completely. Rapid expansion does that with gases. The expansion or contraction of a gas under pressure is adiabatic, meaning that there is a temperature change associated with the volume change. For an ideal gas, this relationship is expressed with PV=nRT. By performing mechanical work on a gas to change its volume, the temperature can be forced to change as well.
Now for coefficient of discharge. Say you have 2 downpipes that flow the same amount of air at the same pressure differential, but one of these pipes has a cross sectional area twice that of the other. The larger DP will have a coefficient of discharge that is half that of the smaller one.
Why? Velocity. Velocity is inversely proportional to an increase in cross sectional area. Doubling the cross sectional are will cut the velocity in half, and halving the cross sectional area will double the velocity.
You can probably see where Im going with all this..
Ive spent quite a few hours with my nose in the fluids books and learned quite a bit. I applied my knowledge to intake manifold design and managed to pull something off no one had been able to do in the mustang world. I beat the best in the business by far, and did something people said was impossible. Ill be getting a mention in 5.0 magazine next month, even though I quit doing this stuff 2 years ago. While I'm wrong about things just as often as anyone, I refuse to accept conventional wisdom alot of the time cause that leads to nothing but closed doors, and its pretty boring too.
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
