3000 stall converter for 350 trans
49-blues
Hardly used 3000 stall converter from level-10 transmissions from when they rebuilt my 350 trans-has less than 1500 miles on it- cost me over $350. - best offer or trade for parts. went to a T-70 turbo and now i need like a 3600 stall.
Not sure if the splines are the same- i ll try to find out for you. CK Performance would know.
The consensus is that it will work, the only difference is instead of using nuts and bolts to mount it like on the chevy, you only need to use the bolts cause the theaded nuts are already mounted on the converter.
