I'm glad to see that the Quad 4 is listed. Not only is this engine a piece, but fixing the garbage that breaks (ie head gasket/ water pump change) made me want to run the car down the hill and into a tree.
The Chrysler/Mitsu 3.0 engine is pretty junky. I like the "Uncle Buck trail of oil smoke" they leave.
On the other hand, I have a N/A 301 and it has given me 165,000+ miles trouble free. Doesn't even burn oil and still has good compression ( I have had this engine checked over to make sure that it was ok since it didn't burn any oil). I only have 2 bbl on it, but it accelerates pretty good for an everyday driver. Gas mileage: I did get about 31 MPG on a trip from CT to Harrisburg PA. I didn't believe it myself until I did a return trip and got similar results. It also has minimal emissions junk on it: No air pump, not alot of vacuum lines etc.
This engine is easy to work on. It's too bad GM didn't put more development into this engine instead of that junky 4100. Maybe some of the weakness could have been corrected.
B4Black, you are absolutely right, a misunderstood engine. For the times: 1979, a second oil crisis, CAFE standards increasing, pollution standards getting stricter, the 301 isn't all that bad.
The GM 3.8 V6 is by far the best engine ever designed. The day they quit making those will be a very sad one. As sad as the last turbo Buick.
