3200 or 2800??
stk6bngr
hello everyone.... im trying to decide which stall to go with. im getting ready to purchase a pi vigilante 5 disk and im not sure if i should go with 3200 or 2800.
i have stock ported heads with bigger ingtake valves 3 inch dp, 3inch dual exhuast, pte 6765bb turbo and all other supporting mods. stock cam and internals.
ive heard some people using a 2800 stall and working real good and some using a 3200 and having to much stall and some working great.
which to use?? any input would be greatly appreciated.
thanks.
With the 3200 stall you may want to look at a 67double BB Q trim or S trim whatever they make these days.
Assuming the heads are ported nicely that should also aide spooling so a 2800 with a regular 67DBB should work well.
Do they make a 0 pump with the 5 disk?
I was told that should be around 3K stall and might be optimum for you.
Thanks for all the replies... I think im going to go with a 3200 stall...
hey sixbangr those heads i bought from you made a big difference with the ta49. thanks man.
