blacknight80
- Dec 26, 2013
hey guys,
I know this is a transmission question but I figured it belongs here as its a little special to the early cars. So my car is an 82 but I have since swapped the top end over to HA. I want to make my tcc work with the 85 harness and I know it has been done but I can't seem to be able to figure it out. Here's the deal my 82' shop manual shows a couple diagrams for the computer command control 350c but nothing seems to jive with what the car had for wiring. One shows a two wire setup and the other shows all 4 pins being utilized in the 4 prong plug. My original harness has 4 wires in the plug which would lead me to believe that is the setup I have but the manual says the 4 wire is specific to the mx-5 and the two wire is for mv4 and mx2. My car has mx2 on the passenger side bellhousing so is it possible that Buick had a mx2 trans wired like the mx5 for the turbo cars?
If I check my wire schematics there are 4 wires coming from the ecm but two are not marked with a color they only have a wire number.
The 82' plug has a purple (12v brake pedal feed), tan/black (connects to ecm/aldl), green (no idea) and a yellow (no idea).
