It's not SC, but it is a 3800.
I have a 98 LeSabre, the SES light went on, and the car died. It wouldn't turn over, probably from the water in the cylinders, but it would go backwards. When I tore the engine down, there was antifreeze in every cylinder, and the intake. I figured that the intake was full from my turning the engine backwards, and forcing it back into the manifold. Now, I spent a couple of days stripping the motor down and replacing the head gaskets, which didn't look blown. (Of course the only blown head gaskets I have seen were the ones that had catastrophic failure from too much boost). The center coolant ports on the intake gaskets were messed up though, but the intake ports weren't. I figured this might be the leak.
Well, I put it all together, and filled the radiator with water. It started up almost immediately, but ran crappy and the SES light was blinking. It only ran for about 30 seconds and died, then wouldn't even crank over. Hydro-locked. I pulled all of the plugs. They all were wet with water, and two of the cylinders actually had water pouring out of the plug holes, there was that much in there. Now, I may not know what the problem is, but I do know that this is not as simple as a gasket seeping. At least I don't think that it is. Does anyone have any ideas. The motor just turned 100,000 miles just days earlier, but it had no cylinder ridge, and you can still see the crosshatch in the bores. I did see what looked like a blemish/scratch in one of the cylinders, could this be a crack? I couldn't feel anything, and I wouldn't think that water would get in all of the cylinders from this. I'd like to save this motor/car, but I don't want to waste my time throwing money at it and still have to replace the motor. I'm wondering if I should just replace the motor with a used one. Any helpis greatly appreciated. Sorry for the length.
